Philco 80 7421 Transformer
Is there away to take this transformer apart and redo the wires. The isolation on the wire is very brittle. If I move the wire it cracks.
Philco 80 7421 Transformer - by Bradley Rush - 11-03-2011, 01:13 AM
Re: Philco 80 7421 Transformer - by 7estatdef - 11-03-2011, 02:49 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-03-2011, 08:47 AM
Re: Philco 80 7421 Transformer - by Carl Travis - 11-03-2011, 09:15 AM
Re: Philco 80 7421 Transformer - by 7estatdef - 11-03-2011, 11:10 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-04-2011, 09:39 AM
Re: Philco 80 7421 Transformer - by Ron Ramirez - 11-04-2011, 09:51 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-05-2011, 12:43 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-05-2011, 06:17 PM
The speaker table error?
Philco 70 antenna lead
