finally beginning 118
Thanks to you and Chuck for the pictures. As I thought I'm missing the bracket that actually holds the bulb in place. Looks like I'm going to replace/repair something to hold the bulb in place. Below are some photos of my 118h. If you need more just let me know. I'll post again once the radio is completed.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:12 PM
RE: finally beginning 118 - by Glenn Roberts - 06-16-2012, 03:56 PM
RE: finally beginning 118 - by Glenn Roberts - 06-17-2012, 08:18 PM
RE: finally beginning 118 - by TA Forbes - 06-17-2012, 11:11 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 01:26 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 06:57 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 07:13 PM
RE: finally beginning 118 - by Ron Ramirez - 06-20-2012, 07:42 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 08:07 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:43 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:46 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 12:51 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 01:02 PM
RE: finally beginning 118 - by 7estatdef - 06-21-2012, 04:05 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 04:18 PM
RE: finally beginning 118 - by Glenn Roberts - 06-23-2012, 08:43 PM
RE: finally beginning 118 - by Ron Ramirez - 06-24-2012, 07:29 AM
RE: finally beginning 118 - by TA Forbes - 06-24-2012, 12:29 PM
Re: finally beginning 118 - by ipwizard - 10-03-2011, 01:26 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:28 PM
Re: finally beginning 118 - by codefox1 - 10-03-2011, 02:22 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 02:26 PM
Re: finally beginning 118 - by TA Forbes - 10-03-2011, 10:57 PM
Re: finally beginning 118 - by Glenn Roberts - 10-04-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-06-2011, 09:03 PM
Re: finally beginning 118 - by Glenn Roberts - 10-07-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-08-2011, 01:08 AM
Re: finally beginning 118 - by Glenn Roberts - 10-08-2011, 04:17 AM
Re: finally beginning 118 - by Glenn Roberts - 10-12-2011, 06:10 PM
Re: finally beginning 118 - by PhilcoMike - 11-02-2011, 09:15 AM
Re: finally beginning 118 - by Glenn Roberts - 11-02-2011, 09:19 AM
Re: finally beginning 118 - by PhilcoMike - 11-03-2011, 08:19 AM
Re: finally beginning 118 - by Chuck Schwark - 11-03-2011, 01:54 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:22 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:41 PM
Re: finally beginning 118 - by PhilcoMike - 11-04-2011, 08:55 AM
Re: finally beginning 118 - by joejoe - 12-07-2011, 02:11 AM
Re: finally beginning 118 - by Glenn Roberts - 12-07-2011, 03:24 PM
Re: finally beginning 118 - by joejoe - 12-07-2011, 08:44 PM
Re: finally beginning 118 - by Glenn Roberts - 12-23-2011, 04:11 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 02:31 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 02:47 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 05:00 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 05:03 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 04:06 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 05:43 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 06:41 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 07:40 PM
The speaker table error?
Philco 70 antenna lead
