finally beginning 118
Thanks Chuck, I looked briefly for info on your site, but I'm not far enough yet to get down with the serious work of rewinding the coil. A link to the info is:
http://www.philcorepairbench.com/tips/svctip01.htm
I have 3 with shadowmeters so this info will definitely come in handy.
Thanks Again,
Glenn
finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:12 PM
RE: finally beginning 118 - by Glenn Roberts - 06-16-2012, 03:56 PM
RE: finally beginning 118 - by Glenn Roberts - 06-17-2012, 08:18 PM
RE: finally beginning 118 - by TA Forbes - 06-17-2012, 11:11 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 01:26 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 06:57 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 07:13 PM
RE: finally beginning 118 - by Ron Ramirez - 06-20-2012, 07:42 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 08:07 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:43 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:46 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 12:51 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 01:02 PM
RE: finally beginning 118 - by 7estatdef - 06-21-2012, 04:05 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 04:18 PM
RE: finally beginning 118 - by Glenn Roberts - 06-23-2012, 08:43 PM
RE: finally beginning 118 - by Ron Ramirez - 06-24-2012, 07:29 AM
RE: finally beginning 118 - by TA Forbes - 06-24-2012, 12:29 PM
Re: finally beginning 118 - by ipwizard - 10-03-2011, 01:26 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:28 PM
Re: finally beginning 118 - by codefox1 - 10-03-2011, 02:22 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 02:26 PM
Re: finally beginning 118 - by TA Forbes - 10-03-2011, 10:57 PM
Re: finally beginning 118 - by Glenn Roberts - 10-04-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-06-2011, 09:03 PM
Re: finally beginning 118 - by Glenn Roberts - 10-07-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-08-2011, 01:08 AM
Re: finally beginning 118 - by Glenn Roberts - 10-08-2011, 04:17 AM
Re: finally beginning 118 - by Glenn Roberts - 10-12-2011, 06:10 PM
Re: finally beginning 118 - by PhilcoMike - 11-02-2011, 09:15 AM
Re: finally beginning 118 - by Glenn Roberts - 11-02-2011, 09:19 AM
Re: finally beginning 118 - by PhilcoMike - 11-03-2011, 08:19 AM
Re: finally beginning 118 - by Chuck Schwark - 11-03-2011, 01:54 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:22 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:41 PM
Re: finally beginning 118 - by PhilcoMike - 11-04-2011, 08:55 AM
Re: finally beginning 118 - by joejoe - 12-07-2011, 02:11 AM
Re: finally beginning 118 - by Glenn Roberts - 12-07-2011, 03:24 PM
Re: finally beginning 118 - by joejoe - 12-07-2011, 08:44 PM
Re: finally beginning 118 - by Glenn Roberts - 12-23-2011, 04:11 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 02:31 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 02:47 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 05:00 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 05:03 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 04:06 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 05:43 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 06:41 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 07:40 PM
The speaker table error?
Philco 70 antenna lead
