finally beginning 118
Glenn,
Thanks much for the cabinet photos, gives me a goal to aim for.
BTW, mine still has the original grill cloth on the speaker if you need that info just let me know.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:12 PM
RE: finally beginning 118 - by Glenn Roberts - 06-16-2012, 03:56 PM
RE: finally beginning 118 - by Glenn Roberts - 06-17-2012, 08:18 PM
RE: finally beginning 118 - by TA Forbes - 06-17-2012, 11:11 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 01:26 PM
RE: finally beginning 118 - by Glenn Roberts - 06-18-2012, 06:57 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 07:13 PM
RE: finally beginning 118 - by Ron Ramirez - 06-20-2012, 07:42 PM
RE: finally beginning 118 - by Glenn Roberts - 06-20-2012, 08:07 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:43 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 12:46 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 12:51 PM
RE: finally beginning 118 - by TA Forbes - 06-21-2012, 01:02 PM
RE: finally beginning 118 - by 7estatdef - 06-21-2012, 04:05 PM
RE: finally beginning 118 - by Glenn Roberts - 06-21-2012, 04:18 PM
RE: finally beginning 118 - by Glenn Roberts - 06-23-2012, 08:43 PM
RE: finally beginning 118 - by Ron Ramirez - 06-24-2012, 07:29 AM
RE: finally beginning 118 - by TA Forbes - 06-24-2012, 12:29 PM
Re: finally beginning 118 - by ipwizard - 10-03-2011, 01:26 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 01:28 PM
Re: finally beginning 118 - by codefox1 - 10-03-2011, 02:22 PM
Re: finally beginning 118 - by Glenn Roberts - 10-03-2011, 02:26 PM
Re: finally beginning 118 - by TA Forbes - 10-03-2011, 10:57 PM
Re: finally beginning 118 - by Glenn Roberts - 10-04-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-06-2011, 09:03 PM
Re: finally beginning 118 - by Glenn Roberts - 10-07-2011, 04:02 AM
Re: finally beginning 118 - by Arran - 10-08-2011, 01:08 AM
Re: finally beginning 118 - by Glenn Roberts - 10-08-2011, 04:17 AM
Re: finally beginning 118 - by Glenn Roberts - 10-12-2011, 06:10 PM
Re: finally beginning 118 - by PhilcoMike - 11-02-2011, 09:15 AM
Re: finally beginning 118 - by Glenn Roberts - 11-02-2011, 09:19 AM
Re: finally beginning 118 - by PhilcoMike - 11-03-2011, 08:19 AM
Re: finally beginning 118 - by Chuck Schwark - 11-03-2011, 01:54 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:22 PM
Re: finally beginning 118 - by Glenn Roberts - 11-03-2011, 05:41 PM
Re: finally beginning 118 - by PhilcoMike - 11-04-2011, 08:55 AM
Re: finally beginning 118 - by joejoe - 12-07-2011, 02:11 AM
Re: finally beginning 118 - by Glenn Roberts - 12-07-2011, 03:24 PM
Re: finally beginning 118 - by joejoe - 12-07-2011, 08:44 PM
Re: finally beginning 118 - by Glenn Roberts - 12-23-2011, 04:11 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 02:31 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 02:47 PM
Re: finally beginning 118 - by joejoe - 01-12-2012, 05:00 PM
Re: finally beginning 118 - by Glenn Roberts - 01-12-2012, 05:03 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 04:06 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 05:43 PM
Re: finally beginning 118 - by joejoe - 01-23-2012, 06:41 PM
Re: finally beginning 118 - by Glenn Roberts - 01-23-2012, 07:40 PM
The speaker table error?
Philco 70 antenna lead
