Philco 80 7421 Transformer
The wire insulation is very brittle. I can not see how far down inside they might have broken. Is the 7421 the same ohms : 1-2 1042 ohms 3-5 .25 ohms 6-7 .15 ohms and 8-10 363 ohms? I am reading 1-2 920 ohms i need to take off the other leads to be sure. But messing with the insulation breaks. All ready for 1-2 I had to replace the wire to the hole.
Philco 80 7421 Transformer - by Bradley Rush - 11-03-2011, 01:13 AM
Re: Philco 80 7421 Transformer - by 7estatdef - 11-03-2011, 02:49 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-03-2011, 08:47 AM
Re: Philco 80 7421 Transformer - by Carl Travis - 11-03-2011, 09:15 AM
Re: Philco 80 7421 Transformer - by 7estatdef - 11-03-2011, 11:10 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-04-2011, 09:39 AM
Re: Philco 80 7421 Transformer - by Ron Ramirez - 11-04-2011, 09:51 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-05-2011, 12:43 AM
Re: Philco 80 7421 Transformer - by Bradley Rush - 11-05-2011, 06:17 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5442 online users. [Complete List]
» 1 Member(s) | 5441 Guest(s)
