Philco 71 restoration
#31
Here is a couple pics of the coil rewind in case anyone wants to see what it looks like.
[Image: http://i1129.photobucket.com/albums/m501...G_2239.jpg]
Secondary half removed from coil form. Pay attention to the direction the coil is wound if its wound backwards it will not work (Thanks Terry).
[Image: http://i1129.photobucket.com/albums/m501...G_2241.jpg]
After removing the rest of the wire the secondary was rewound with 32ga magnet wire. I started from the top to the bottom as it was easier.
[Image: http://i1129.photobucket.com/albums/m501...G_2242.jpg]
Another view of the rewound coil. I soldered the ends to the lugs and then applyed Q-Dope to the coil to hold it in place.
Here is a neat video about transformer (coil) phasing. This guy has lots of neat videos about tube radios, and circuits.
http://www.youtube.com/user/AllAmericanF...RBqUQPLk-M
-Keith
Philco 71 restoration - by ipwizard - 09-29-2011, 12:48 AM
RE: Philco 71 restoration - by ipwizard - 03-02-2012, 06:09 PM
Re: Man this thing is a nightmare - by ipwizard - 09-29-2011, 01:36 AM
Re: Man this thing is a nightmare - by ipwizard - 09-29-2011, 10:14 PM
Re: Man this thing is a nightmare - by ipwizard - 10-06-2011, 12:29 AM
Re: Man this thing is a nightmare - by Arran - 10-06-2011, 02:24 AM
Re: Man this thing is a nightmare - by rghines1 - 10-06-2011, 10:20 AM
Re: Man this thing is a nightmare - by exray - 10-06-2011, 12:41 PM
Re: Man this thing is a nightmare - by ipwizard - 10-08-2011, 10:34 PM
Re: Man this thing is a nightmare - by Marsupial - 10-08-2011, 11:52 PM
Re: Man this thing is a nightmare - by exray - 10-09-2011, 05:56 AM
Re: Man this thing is a nightmare - by ipwizard - 10-10-2011, 01:40 PM
Re: Philco 71 restoration - by ipwizard - 10-31-2011, 05:10 PM
Re: Philco 71 restoration - by 7estatdef - 10-31-2011, 08:48 PM
Re: Philco 71 restoration - by 7estatdef - 10-31-2011, 09:00 PM
Re: Philco 71 restoration - by ipwizard - 11-01-2011, 01:03 AM
Re: Philco 71 restoration - by ipwizard - 11-01-2011, 01:06 AM
Re: Philco 71 restoration - by 7estatdef - 11-01-2011, 10:58 PM
Re: Philco 71 restoration - by ipwizard - 11-03-2011, 01:03 AM
Re: Philco 71 restoration - by 7estatdef - 11-03-2011, 02:59 AM
Re: Philco 71 restoration - by codefox1 - 11-03-2011, 10:04 AM
Re: Philco 71 restoration - by ipwizard - 11-03-2011, 06:00 PM
Re: Philco 71 restoration - by 7estatdef - 11-03-2011, 06:26 PM
Re: Philco 71 restoration - by ipwizard - 11-03-2011, 06:31 PM
Re: Philco 71 restoration - by 7estatdef - 11-03-2011, 06:42 PM
Re: Philco 71 restoration - by ipwizard - 11-03-2011, 07:40 PM
Re: Philco 71 restoration - by 7estatdef - 11-03-2011, 08:39 PM
Re: Philco 71 restoration - by ipwizard - 11-03-2011, 09:38 PM
Re: Philco 71 restoration - by ipwizard - 11-04-2011, 12:29 AM
Re: Philco 71 restoration - by ipwizard - 11-04-2011, 02:33 PM
Re: Philco 71 restoration - by ipwizard - 11-30-2011, 11:56 PM
Re: Philco 71 restoration - by TA Forbes - 12-01-2011, 12:37 AM
Re: Philco 71 restoration - by TA Forbes - 12-02-2011, 09:54 PM
Re: Philco 71 restoration - by codefox1 - 12-03-2011, 11:48 AM
Re: Philco 71 restoration - by ipwizard - 12-04-2011, 03:03 PM
Re: Philco 71 restoration - by ipwizard - 12-23-2011, 04:36 AM
The speaker table error?
Philco 70 antenna lead
