Philco 20 restoration state: need the voltage chart
Let me scratch my head a bit more. I've got a working 20 I'll take a look at it and see what the voltages are on it. Just for laughs you could ground the cathode and see what the plate voltage is.
The caps in the big can are paper/non polarize. Once you get the can hot (in the oven @ 275 for 30 mins. You'll need something like a cork screw to pull out the paper caps, there in there pretty tight.
Yes GB. You type with a bit of an ascent. I get over to Jersey a lot for work. Tomorrow I'm headed up to Basking Ridge.
Re: Philco 20 restoration state: need the voltage chart - by 7estatdef - 11-04-2011, 06:06 PM
91H Code 126 Restore
Philco 70 antenna lead
