40-150 Update
I've started working on my 40-150 and found this set of electrolytics under the chassis. The parts list and schematic call for one 16mfd - 200v, and one 12mfd - 350v, both residing in a topmount can. However, one side is disconnected and replaced with a pair of 10mfd - 500v caps and the other side has all the pins soldered together. I figured it was a hack job until I searched the internet for info on repairing a 40-150 and saw two other chassis with virtually the identical setup underneath. What does piggy-backing a pair of lytics like this accomplish?
Schematic here:
http://www.nostalgiaair.org/resources/331/M0013331.htm
[attachment=0]
Larry
40-150 Update - by rocketeer - 11-04-2011, 06:43 PM
Re: 40-150 electrolytics question - by rocketeer - 11-05-2011, 06:52 PM
Re: 40-150 electrolytics question - by Arran - 11-05-2011, 11:04 PM
Re: 40-150 electrolytics question - by gvel - 11-06-2011, 09:11 AM
Re: 40-150 electrolytics question - by rocketeer - 11-06-2011, 10:30 AM
Re: 40-150 electrolytics question - by 7estatdef - 11-08-2011, 04:37 PM
Re: 40-150 electrolytics question - by rocketeer - 11-20-2011, 03:53 PM
Re: 40-150 Update - by gvel - 11-20-2011, 05:49 PM
Re: 40-150 Update - by rocketeer - 11-21-2011, 05:55 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 7242 online users. [Complete List]
» 1 Member(s) | 7241 Guest(s)
