Philco 20 restoration state: need the voltage chart
Ron Ramirez Wrote:The copper Mershons are now highly collectible. When polished up and installed in a clean chassis, they look great in a 70 or a 90, or any Philco of the period that used them, for that matter.
I take it, they are used for their exterior only, housing a new electrolytic cap inside? Or do they survive to be actually used by itself?
Re: Philco 20 restoration state: need the voltage chart - by morzh - 11-05-2011, 12:26 PM
91H Code 126 Restore
Philco 70 antenna lead
