philco automatic tuning call tabs??
Hi
I've never heard of anyone reproducing these. It could be done fairly simply, with one's home computer. Just a matter of finding the correct font and running with it.
philco automatic tuning call tabs?? - by philconut - 11-05-2011, 10:24 PM
Re: philco automatic tuning call tabs?? - by Ron Ramirez - 11-06-2011, 08:50 AM
Philco 91 Tuning Condenser
There are currently 4708 online users. [Complete List]
» 1 Member(s) | 4707 Guest(s)
