Factory installed? Philco 89 Chassis in a Philco 35 Cabinet
Here is the front. So either somebody went through alot of trouble to post an 89 label in there or this was done at the factory. That glue looks mighty original. The date stamp inside the cabinet is Mar23 4. (March 23 1934). Note the stamp was not under the cabinet but inside just above the 89 label. The chassis serial is H58826. I have another 89 with a serial H41375 in a normal sized cathedral cabinet.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 3319 online users. [Complete List]
» 1 Member(s) | 3318 Guest(s)
