Sharing my basket case project for the Winter (or earlier).
Sometimes you can hear radio's calling out for help, this seems to be one! It would be great to see a few 'in progress' photos, you must be talented in the art of cabinet reconstruction....best of luck
[No subject] - by Terry Judkins - 09-28-2006, 09:54 PM
[No subject] - by Drew - 09-30-2006, 06:55 AM
[No subject] - by Ron Ramirez - 09-30-2006, 08:56 AM
[No subject] - by gary rabbitt - 09-30-2006, 08:29 PM
[No subject] - by Ron Ramirez - 10-04-2006, 09:04 AM
[No subject] - by Poston Drake - 10-19-2006, 06:28 PM
There are currently 10823 online users. [Complete List]
» 2 Member(s) | 10821 Guest(s)
