Using a Signal Generator
Hi all,
I just bought a EICO 330 Signal Generator and will use it to isolate defects in specific stages. It has a coax output cable with alligator clips.
Everything I read, including the EICO manual, stresses that I put a .01 mf cap in the negative lead and a 200 pf cap in series in the hot lead. I don't understand. I can solder a cap on the ground and clip onto it, but how do I put the cap in series in the hot lead and use it to probe?
Alan
Using a Signal Generator - by lasurveyor - 11-07-2011, 10:48 AM
Re: Using a Signal Generator - by 7estatdef - 11-07-2011, 11:50 AM
Re: Using a Signal Generator - by LASJayhawk - 11-07-2011, 06:21 PM
Re: Using a Signal Generator - by lasurveyor - 11-08-2011, 08:44 PM
Re: Using a Signal Generator - by codefox1 - 11-08-2011, 11:16 PM
The speaker table error?
Philco 70 antenna lead
