Sharing my basket case project for the Winter (or earlier).
Gary,
WOW (or should I say UGH)! You certainly have your work cut out for you there, eh! But I have a feeling you will bring that cabinet back to its former glory much easier than a lot of us could. I second Drew's suggestion of sharing "in progress" photos as you go along on the cabinet. Good luck!
[No subject] - by Terry Judkins - 09-28-2006, 09:54 PM
[No subject] - by Drew - 09-30-2006, 06:55 AM
[No subject] - by Ron Ramirez - 09-30-2006, 08:56 AM
[No subject] - by gary rabbitt - 09-30-2006, 08:29 PM
[No subject] - by Ron Ramirez - 10-04-2006, 09:04 AM
[No subject] - by Poston Drake - 10-19-2006, 06:28 PM
