Sharing my basket case project for the Winter (or earlier).
For every radio I've seen like this, I could only see potential. I have seen worse. I've brought back some to life, others am still working on. I bought a philco model eighty four at a local flea market for ten dollars this past year. I should post you the before's of this one, as there's no after yet. Another worth while project.
You'll do great with this one. Trust yourself, and the good people of this web site who are very knowledgeable of Philco radios.
73 de,
Gary/N9VU
[No subject] - by Terry Judkins - 09-28-2006, 09:54 PM
[No subject] - by Drew - 09-30-2006, 06:55 AM
[No subject] - by Ron Ramirez - 09-30-2006, 08:56 AM
Re: Sharing my basket case project for the Winter (or earlie - by n9vu - 09-30-2006, 03:01 PM
[No subject] - by gary rabbitt - 09-30-2006, 08:29 PM
[No subject] - by Ron Ramirez - 10-04-2006, 09:04 AM
[No subject] - by Poston Drake - 10-19-2006, 06:28 PM
Philco 91 Tuning Condenser
There are currently 9978 online users. [Complete List]
» 1 Member(s) | 9977 Guest(s)
