Factory installed? Philco 89 Chassis in a Philco 35 Cabinet
Yes, the model 32 uses a vibrator power supply to provide high voltage for the set. This was Philco's first 32 volt set. A later 32 volt set (model 642) did use 32 volts for the B+.
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 1692 online users. [Complete List]
» 1 Member(s) | 1691 Guest(s)
