Radio Daze Philco dial reproductions
Hi Ken
If you like pale yellow, almost white, dial scales - then, yes, I guess you could say they are good. If they are still using the Rock-Sea artwork (and I believe they are), then the artwork itself is accurate - just the color of the dial scales themselves that are too light.
Send me a PM with your mailing address, I'll send you a 37-650 scale, free. I think you'll like it better than a RD repro.
Re: Radio Daze Philco dial reproductions - by Ron Ramirez - 11-10-2011, 08:11 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
