no reception 57C
Hello,
Yesterday picked up a 1933 57C at a local auction..$15 Bucks .It had a new, but period ac cord, when I got home sure enough it had already been recapped ( Need to check for correctness ), tubes are correct. Turns on , but gets virtually no reception, very faint hum and occasional static chirp when volume control is turned back and forth.
Where should I start and what should be my first checks ? I have the schematics and parts layout, are there any points where I can check for correct voltages, etc, there are none shown on the schematic.
Kurt/ Newbie now hooked.
no reception 57C - by kbm37-630 - 11-12-2011, 08:43 PM
Re: no reception 57C - by Ron Ramirez - 11-13-2011, 07:30 AM
Re: no reception 57C - by Ron Ramirez - 11-13-2011, 07:33 AM
Re: no reception 57C - by kbm37-630 - 11-13-2011, 01:44 PM
Re: no reception 57C - by 7estatdef - 11-14-2011, 06:37 PM
Re: no reception 57C - by kbm37-630 - 11-19-2011, 10:50 AM
Re: no reception 57C - by gvel - 11-20-2011, 10:51 AM
Re: no reception 57C - by 7estatdef - 11-20-2011, 03:34 PM
Re: no reception 57C - by kbm37-630 - 11-20-2011, 06:16 PM
Re: no reception 57C - by 7estatdef - 11-21-2011, 02:09 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5954 online users. [Complete List]
» 1 Member(s) | 5953 Guest(s)
