Fighting with the Philco 111
I will have to pull the bottom off the chassis off and see what's going on under there. It was fine on the test bench and such. Only got crappy once I put it back into the cabinet last year.
Fighting with the Philco 111 - by Jayce - 11-06-2011, 07:27 PM
Re: Fighting with the Philco 111 - by Arran - 11-08-2011, 12:35 AM
Re: Fighting with the Philco 111 - by Ron Ramirez - 11-12-2011, 12:13 PM
Re: Fighting with the Philco 111 - by Jayce - 11-12-2011, 11:42 PM
Re: Fighting with the Philco 111 - by Jayce - 11-16-2011, 02:37 PM
91H Code 126 Restore
Philco 70 antenna lead
