Tuning Cap protection
I wouldn't do it lest you get some inside the plates. No problem brushing some laquer clear or silver color on the frame but be careful.
Tuning Cap protection - by ipwizard - 11-13-2011, 01:36 AM
Re: Tuning Cap protection - by codefox1 - 11-13-2011, 02:01 AM
Re: Tuning Cap protection - by Chuck Schwark - 11-15-2011, 02:29 PM
91H Code 126 Restore
Philco 70 antenna lead
