Advice on Philco 70A basket case
I think if you do a little looking you can find someone that can rewind your field coil. A replacement transformer shouldn't be a problem to find. If you do go with a PM speaker and a resistor instead of the field coil you will find that you will need to up the value of the filters to reduce the hum. The field coil or a choke will help filter the hum out much better than a resistor with less of a voltage drop.
Re: Advice on Philco 70A basket case - by 7estatdef - 11-14-2011, 06:15 PM
Re: Advice on Philco 70A basket case - by morzh - 11-15-2011, 12:08 PM
Re: Advice on Philco 70A basket case - by Arran - 11-20-2011, 01:19 AM
91H Code 126 Restore
There are currently 5574 online users. [Complete List]
» 1 Member(s) | 5573 Guest(s)
