Philco 38-12 dial lamp and 6A7 Tube
Pull out the 6A7. Take your ohm meter and hook it to the two fat pins of the 6A7. Should read a very low resistance like .5ohm. If not you will need to replace the 6A7, it's DEAD
Terry N3GTE
Philco 38-12 dial lamp and 6A7 Tube - by aa8rv - 11-07-2011, 04:15 PM
Re: Philco 38-12 dial lamp and 6A7 Tube - by 7estatdef - 11-14-2011, 07:06 PM
The speaker table error?
Philco 70 antenna lead
