philco model 37-60b speaker
Hello I need help with how to wire up the speaker it has three wires and I'm lost which one go's where? I can send a picture if needed I also need to replace the wires and I need a schematic or drawing to find out where to hook up the other end.thanks for allowing me to join this is my first post.
philco model 37-60b speaker - by tom - 11-14-2011, 08:07 PM
Re: philco model 37-60b speaker - by 7estatdef - 11-14-2011, 08:43 PM
Philco 91 Tuning Condenser
There are currently 5808 online users. [Complete List]
» 1 Member(s) | 5807 Guest(s)
