Bad Transformer?
If XFMR ever smoked, this is it - even if it no longer smokes when you pulled out the diode tube, it is damaged.
Bad Transformer? - by Dark High - 10-28-2011, 09:19 AM
Re: Bad Transformer? - by Texasrocker - 10-28-2011, 03:15 PM
Re: Bad Transformer? - by Dark High - 10-28-2011, 08:00 PM
Re: Bad Transformer? - by Arran - 10-28-2011, 09:19 PM
Re: Bad Transformer? - by gvel - 10-29-2011, 10:28 AM
Re: Bad Transformer? - by Dark High - 11-14-2011, 09:32 PM
Re: Bad Transformer? - by 7estatdef - 11-15-2011, 12:30 AM
Re: Bad Transformer? - by morzh - 11-15-2011, 12:10 PM
Re: Bad Transformer? - by Chuck Schwark - 11-15-2011, 12:36 PM
Re: Bad Transformer? - by codefox1 - 11-15-2011, 02:28 PM
Re: Bad Transformer? - by Dark High - 11-15-2011, 03:45 PM
Re: Bad Transformer? - by Ron Ramirez - 11-15-2011, 05:13 PM
Re: Bad Transformer? - by Dark High - 11-16-2011, 05:56 PM
Re: Bad Transformer? - by 7estatdef - 11-16-2011, 07:05 PM
Re: Bad Transformer? - by james1095 - 11-17-2011, 02:43 AM
Re: Bad Transformer? - by Dark High - 11-17-2011, 09:17 PM
Re: Bad Transformer? - by 7estatdef - 11-17-2011, 11:44 PM
Re: Bad Transformer? - by Dark High - 11-18-2011, 10:33 AM
Re: Bad Transformer? - by Dark High - 11-18-2011, 04:04 PM
Re: Bad Transformer? - by morzh - 11-18-2011, 10:24 PM
Re: Bad Transformer? - by Dark High - 11-21-2011, 01:14 PM
Re: Bad Transformer? - by 7estatdef - 11-21-2011, 02:03 PM
Re: Bad Transformer? - by james1095 - 11-22-2011, 01:33 AM
Re: Bad Transformer? - by Dark High - 11-22-2011, 10:53 AM
Re: Bad Transformer? - by codefox1 - 11-22-2011, 04:47 PM
Re: Bad Transformer? - by 7estatdef - 11-23-2011, 12:28 AM
Re: Bad Transformer? - by Texasrocker - 11-23-2011, 10:41 PM
Re: Bad Transformer? - by james1095 - 11-25-2011, 03:20 AM
Re: Bad Transformer? - by Dark High - 11-28-2011, 01:00 PM
Re: Bad Transformer? - by Dark High - 11-28-2011, 01:01 PM
Re: Bad Transformer? - by Dark High - 11-28-2011, 04:19 PM
Re: Bad Transformer? - by morzh - 11-28-2011, 06:25 PM
Re: Bad Transformer? - by Dark High - 11-29-2011, 11:54 AM
Re: Bad Transformer? - by morzh - 11-29-2011, 05:52 PM
Re: Bad Transformer? - by TA Forbes - 11-29-2011, 08:27 PM
Re: Bad Transformer? - by 7estatdef - 11-29-2011, 09:28 PM
91H Code 126 Restore
