Alignment instructions needed
Ok I went through the alignment again with the sig gen turned all the way down. When I was turning some on the caps the tone would come blasting in through the speaker. I had the Sig gen turned all the way down and on LO setting on the course Attn. Dont know why unless there is something wrong with my sig gen.
But after I Re aligned stations are comeing in better now. But there is a lot of static i tried different antenna and turning everything that generates interference off but I cant clean up the sound. Only the few very strong stations come in loud and clear.
All the coils ohmed out good, tubes tested strong.
best part its getting better!!
-Keith
Alignment instructions needed - by ipwizard - 01-01-2012, 05:18 PM
Re: Alignment instructions needed - by 7estatdef - 01-02-2012, 01:04 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 12:45 AM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 01:14 AM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 07:31 AM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 01:46 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 05:55 PM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 07:16 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 08:50 PM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 11:12 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 11:46 PM
Re: Alignment instructions needed - by 7estatdef - 01-05-2012, 12:16 AM
Re: Alignment instructions needed - by ipwizard - 01-05-2012, 01:42 AM
Re: Alignment instructions needed - by ipwizard - 01-05-2012, 02:00 PM
Re: Alignment instructions needed - by 7estatdef - 01-05-2012, 07:14 PM
Re: Alignment instructions needed - by ipwizard - 01-06-2012, 12:57 AM
Re: Alignment instructions needed - by John R - 01-06-2012, 01:29 PM
Re: Alignment instructions needed - by ipwizard - 01-09-2012, 12:31 AM
Re: Alignment instructions needed - by 7estatdef - 01-09-2012, 09:23 AM
Re: Alignment instructions needed - by ipwizard - 01-09-2012, 01:56 PM
Re: Alignment instructions needed - by ipwizard - 01-11-2012, 12:33 AM
Re: Alignment instructions needed - by ipwizard - 01-13-2012, 01:41 AM
91H Code 126 Restore
