Model 89-123
http://www.philcoradio.com/tech/89evol.htm
Model 89-123 - by brodie - 11-15-2011, 09:37 PM
Re: Model 89-123 - by Ron Ramirez - 11-15-2011, 10:03 PM
Re: Model 89-123 - by brodie - 11-15-2011, 10:44 PM
91H Code 126 Restore
Philco 70 antenna lead
