Model 660X or 665X??
Thanks for the information. I had looked at those pictures and others elsewhere, but found that some of them had labeled the 660 as a 665 and vice versa, so I was confused.
Using these pictures, I can see that I have a 660X. Honestly, I like the 660X cabinet better.
I printed the schematics for each and noted the differences between them. I don't know if the 665 chassis was actually superior or just less expensive to build, as I have noted the deletion of several parts on the 665 chassis. At least my experiences with the other Philcos I have will help --I have a 91, a 16B, two 37-116s, a 38-116 and a 38-690.
Model 660X or 665X?? - by theblurrrr - 10-08-2006, 12:27 AM
[No subject] - by Ron Ramirez - 10-08-2006, 08:58 AM
[No subject] - by Chuck Schwark - 10-08-2006, 10:45 AM
Model 660X - by theblurrrr - 10-08-2006, 11:37 AM
[No subject] - by Chuck Schwark - 10-08-2006, 12:46 PM
[No subject] - by Ron Ramirez - 10-09-2006, 09:57 AM
There are currently 9858 online users. [Complete List]
» 1 Member(s) | 9857 Guest(s)
