Advice on Philco 70A basket case
Thanks again for the photos. They REALLY help. I'll go back and give it another whack. Maybe it's time to bring out the small sledge hammer and a heavy duty socket to place on the back of the pin to bang on?
There seems to be a round flat cap on the back of pole piece (see photos). I don't see it in the photo of yours. Does that also get pounded through the hole or do you somehow have to pry it off or remove it somehow first? So far I have not seen ANY movement.
Re: Advice on Philco 70A basket case - by morzh - 11-15-2011, 12:08 PM
Re: Advice on Philco 70A basket case - by retiredinprescott - 11-16-2011, 03:35 PM
Re: Advice on Philco 70A basket case - by Arran - 11-20-2011, 01:19 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5531 online users. [Complete List]
» 1 Member(s) | 5530 Guest(s)
