Need Philco 345 readable schematic
Dan
I have the Radio College of Canada schematics on a DVD, which is sold by a collector in Canada.
I looked at the 345 schematic...hard to read, and you can't make out most of the part values, but I compared it against the USA 45 schematic and they are the same.
I'll send you a copy of this schematic if you want it, but like I said, the scan is not very clear.
Re: Need Philco 345 readable schematic - by Ron Ramirez - 11-18-2011, 06:43 AM
91H Code 126 Restore
