Philco 41-280
Ok The problem is you have no grid bias. Pin 4 should have about -10vdc on it. At the junction of the two 1meg resistors 53 and 54 what voltage do you have there? Is the negative side of 62 ground to the chassis?
Philco 41-280 - by OldJack1969 - 01-03-2012, 07:08 PM
Re: Philco 41-280 - by 7estatdef - 01-03-2012, 08:52 PM
Re: Philco 41-280 - by OldJack1969 - 01-04-2012, 06:55 PM
Re: Philco 41-280 - by 7estatdef - 01-04-2012, 11:49 PM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 12:00 AM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 01:09 AM
Re: Philco 41-280 - by 7estatdef - 01-05-2012, 07:28 PM
Re: Philco 41-280 - by OldJack1969 - 01-05-2012, 08:25 PM
Re: Philco 41-280 - by 7estatdef - 01-05-2012, 11:28 PM
Re: Philco 41-280 - by OldJack1969 - 01-06-2012, 12:05 AM
Re: Philco 41-280 - by 7estatdef - 01-06-2012, 08:47 AM
Re: Philco 41-280 - by OldJack1969 - 01-06-2012, 01:35 PM
Re: Philco 41-280 - by 7estatdef - 01-06-2012, 05:42 PM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 12:43 AM
Re: Philco 41-280 - by Phlogiston - 01-08-2012, 12:56 AM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 01:10 AM
Re: Philco 41-280 - by 7estatdef - 01-08-2012, 03:30 PM
Re: Philco 41-280 - by OldJack1969 - 01-08-2012, 03:45 PM
Re: Philco 41-280 - by gary rabbitt - 01-23-2012, 08:38 PM
Re: Philco 41-280 - by OldJack1969 - 01-23-2012, 09:29 PM
Re: Philco 41-280 - by gary rabbitt - 01-24-2012, 04:58 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 05:10 PM
Re: Philco 41-280 - by 7estatdef - 01-24-2012, 06:17 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 06:50 PM
Re: Philco 41-280 - by 7estatdef - 01-24-2012, 06:56 PM
Re: Philco 41-280 - by OldJack1969 - 01-24-2012, 07:15 PM
91H Code 126 Restore
