Very sad 116X
A couple of years ago, I learned of an interesting cabinet variation in 116X cabinet production. That is that the veneer on the left and right front cabinet corner radiuses had the grain running horizontally in early production, while in later production the corner veneer grain ran vertically.
My 116X's cabinet was only slightly better than yours before I had a cabinetmaker restore it for me. I installed the reproduction grille cloth myself and I did the chassis work. Here's how it came out. Please notice the corner grain.
[Image: http://i573.photobucket.com/albums/ss171...018F-1.jpg]
Very sad 116X - by rocketeer - 11-18-2011, 12:29 AM
Re: Very sad 116X - by Tom Hamilton - 11-18-2011, 02:42 AM
Re: Very sad 116X - by Arran - 11-19-2011, 01:19 AM
Re: Very sad 116X - by TA Forbes - 11-19-2011, 02:07 AM
Re: Very sad 116X - by DeckApe - 11-19-2011, 11:22 AM
Re: Very sad 116X - by Mal Fuller - 11-19-2011, 11:37 AM
Re: Very sad 116X - by Jayce - 11-19-2011, 02:47 PM
Re: Very sad 116X - by Paul Philco322 - 11-19-2011, 08:27 PM
Re: Very sad 116X - by rocketeer - 11-19-2011, 09:45 PM
Re: Very sad 116X - by TA Forbes - 11-20-2011, 01:20 AM
Re: Very sad 116X - by Ron Ramirez - 11-20-2011, 07:59 AM
Re: Very sad 116X - by Gene Pederson - 11-20-2011, 04:27 PM
Re: Very sad 116X - by rocketeer - 11-20-2011, 04:44 PM
Re: Very sad 116X - by Gene Pederson - 11-20-2011, 04:49 PM
Re: Very sad 116X - by rocketeer - 11-21-2011, 12:51 PM
Re: Very sad 116X - by james1095 - 11-22-2011, 01:38 AM
Re: Very sad 116X - by TA Forbes - 11-22-2011, 07:50 PM
Re: Very sad 116X - by TA Forbes - 11-22-2011, 07:52 PM
Re: Very sad 116X - by BDM - 12-07-2011, 03:45 PM
Re: Very sad 116X - by Ron Ramirez - 12-07-2011, 04:50 PM
Re: Very sad 116X - by BDM - 12-07-2011, 05:28 PM
Re: Very sad 116X - by TA Forbes - 12-07-2011, 11:15 PM
Re: Very sad 116X - by BDM - 12-08-2011, 12:06 AM
Philco 91 Tuning Condenser
There are currently 4681 online users. [Complete List]
» 1 Member(s) | 4680 Guest(s)
