no reception 57C
Hello Greg and Terry,
Thanks for your input.
For old resistor wattage found the answer on the Philcorepairbench site, you can determine the proper wattage based on the size, see attached site.
http://www.philcorepairbench.com/resistcompare.htm
Definitely will rewind the primary instead of replacing the coil.
Terry, The set was already recapped when I found it, I verified that It was done correctly.
Will let you know results asap..
Kurt
no reception 57C - by kbm37-630 - 11-12-2011, 08:43 PM
Re: no reception 57C - by Ron Ramirez - 11-13-2011, 07:30 AM
Re: no reception 57C - by Ron Ramirez - 11-13-2011, 07:33 AM
Re: no reception 57C - by kbm37-630 - 11-13-2011, 01:44 PM
Re: no reception 57C - by 7estatdef - 11-14-2011, 06:37 PM
Re: no reception 57C - by kbm37-630 - 11-19-2011, 10:50 AM
Re: no reception 57C - by gvel - 11-20-2011, 10:51 AM
Re: no reception 57C - by 7estatdef - 11-20-2011, 03:34 PM
Re: no reception 57C - by kbm37-630 - 11-20-2011, 06:16 PM
Re: no reception 57C - by 7estatdef - 11-21-2011, 02:09 PM
91H Code 126 Restore
There are currently 5781 online users. [Complete List]
» 1 Member(s) | 5780 Guest(s)
