Philco 42-1009 code 122 help
Hi
I'm a newby looking for help with a Philco 42-1009 code 122. got the radio going and now working on the phono. All the info I have shows a Beam of light but what is in the console is a VM changer which somebody probably changed it to. The prints I have shows the beam of light connections (pickup goes to points 17 & 18 on the print). The power plug is not a problem as the plug is intact and plugs into the rear of the chassis where it should for 115vac (only 2 leads) but the phono pick up leads are another problem there loose with no connector have no idea on where they go (red and black in the tone arm), I have all the prints from Chuck. Would they go where it shows on the print where the beam would be one side to ground and the other to #18 the 300mmf cap? Any help would be appreciated.
Eric
Philco 42-1009 code 122 help - by Eric - 11-25-2011, 10:48 AM
Re: Philco 42-1009 code 122 help - by 7estatdef - 11-25-2011, 09:18 PM
Re: Philco 42-1009 code 122 help - by Eric - 11-27-2011, 12:16 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 11-27-2011, 06:25 PM
Re: Philco 42-1009 code 122 help - by Eric - 11-27-2011, 07:36 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 11-27-2011, 11:42 PM
Re: Philco 42-1009 code 122 help - by Eric - 12-09-2011, 12:14 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 12-09-2011, 11:45 PM
Re: Philco 42-1009 code 122 help - by Eric - 12-10-2011, 07:04 PM
Re: Philco 42-1009 code 122 help - by Eric - 12-13-2011, 11:05 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 12-14-2011, 05:46 PM
91H Code 126 Restore
Philco 70 antenna lead
