Philco 42-1009 code 122 help
Well it depends wither the cartridge is ceramic (hi Z) or magnetic (low Z). Either way you'll need to connect it to 92 the input transformer. Low Z would hook to the secondary, High Z disconnect the transformer and hook it where the primary was connected.
Philco 42-1009 code 122 help - by Eric - 11-25-2011, 10:48 AM
Re: Philco 42-1009 code 122 help - by 7estatdef - 11-25-2011, 09:18 PM
Re: Philco 42-1009 code 122 help - by Eric - 11-27-2011, 12:16 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 11-27-2011, 06:25 PM
Re: Philco 42-1009 code 122 help - by Eric - 11-27-2011, 07:36 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 11-27-2011, 11:42 PM
Re: Philco 42-1009 code 122 help - by Eric - 12-09-2011, 12:14 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 12-09-2011, 11:45 PM
Re: Philco 42-1009 code 122 help - by Eric - 12-10-2011, 07:04 PM
Re: Philco 42-1009 code 122 help - by Eric - 12-13-2011, 11:05 PM
Re: Philco 42-1009 code 122 help - by 7estatdef - 12-14-2011, 05:46 PM
91H Code 126 Restore
There are currently 5644 online users. [Complete List]
» 1 Member(s) | 5643 Guest(s)
