Philco 91,126 code oscillator coil 05985
All sounds good! The resistance of the new winding doesn't matter so much it's the inductance that's important. The other important thing is the direction of the winding, must be wound the same as original!
Once you get the set put back together you can check the osc by listening for it in another receiver. You can use a small transistor set placed next to the osc tube. Tune the Philco to 1000 kc then tune the transistor set to 1000kc + the IF frequency. I don't remember the IF frequency of the 91 I think it's 260kc which would equal 1260kc. When it's working as you tune the set around 1260 it will get quite or start to squeal.
Re: Philco 91,126 code oscillator coil 05985 - by 7estatdef - 11-25-2011, 09:41 PM
There are currently 9076 online users. [Complete List]
» 2 Member(s) | 9074 Guest(s)
