Have gone over to the other side!
That's all I had to do on this one was replace 4 caps and fix a few broken wires on the loop antenna. A bit of a pain as the wire is very small. The original battery was a 226 which looks like a C cell with snaps on each end and it's 9v. The newer 9v battery would fit but it would put a bit of stress on the plastic cabinet. So I used a pair of vice-grips to shrink the width of the battery. It wasn't very pretty but now I've got a bit of space in the battery space with out stressing the case.
Have gone over to the other side! - by 7estatdef - 11-25-2011, 04:19 PM
Re: Have gone over to the other side! - by TimC - 11-26-2011, 05:27 PM
Re: Have gone over to the other side! - by Jayce - 11-26-2011, 07:02 PM
Re: Have gone over to the other side! - by TimC - 11-26-2011, 08:19 PM
Re: Have gone over to the other side! - by 7estatdef - 11-26-2011, 08:36 PM
Re: Have gone over to the other side! - by Dave - 11-26-2011, 10:27 PM
Re: Have gone over to the other side! - by Dave - 11-27-2011, 12:38 PM
Re: Have gone over to the other side! - by Jayce - 11-29-2011, 10:51 PM
There are currently 4546 online users. [Complete List]
» 1 Member(s) | 4545 Guest(s)
