Removing Poly finish from a Philco 46-480
Thanks guys. The radio does not look too bad but it is so obvious the finish is not of the proper period and it bugs me every time I walk past it. It sounds like I should wait until spring so I can strip it outside. Thanks for the advice.
RE: Removing Poly finish from a Philco 46-480 - by jadaman - 03-19-2012, 09:18 PM
Re: Removing Poly finish from a Philco 46-480 - by Jbaker - 11-26-2011, 09:03 PM
There are currently 7127 online users. [Complete List]
» 1 Member(s) | 7126 Guest(s)
