Have gone over to the other side!
7estatdef Wrote:It was just a short trip over to the other side. My dad worked the Motorola from the mid 60's in to the 1980's. He was on the 2 way radio side not the entertainment side of things. When is see something interesting that's Motorola I pick it up.
I can't fault you for picking Motorola. I'm a bit partial to them myself, and for a similar reason. I'm a tech on the two-way side of the house too.
Dave
Have gone over to the other side! - by 7estatdef - 11-25-2011, 04:19 PM
Re: Have gone over to the other side! - by TimC - 11-26-2011, 05:27 PM
Re: Have gone over to the other side! - by Jayce - 11-26-2011, 07:02 PM
Re: Have gone over to the other side! - by TimC - 11-26-2011, 08:19 PM
Re: Have gone over to the other side! - by Dave - 11-26-2011, 10:27 PM
Re: Have gone over to the other side! - by Dave - 11-27-2011, 12:38 PM
Re: Have gone over to the other side! - by Jayce - 11-29-2011, 10:51 PM
Eico 232 VTVM Schematic
There are currently 6487 online users. [Complete List]
» 2 Member(s) | 6485 Guest(s)
