Antenna for Philco Radio
More so for transmitting than for recieving. An ideal antenna would be a factor of the wavelength that you were transmitting or recieving, i.e. 1Xwavelength, 2Xwavelength, etc... but this could result in a very long antenna. 1/2 or 1/4 wavelength antennas are acceptable alternatives but not as effective.
You can use this equation to calculate wavelength:
wavelength=300/(frequency in MHz)
As frequencies go up, corresponding wavelengths go down.
Antenna for Philco Radio - by SKW40 - 11-21-2011, 10:59 PM
Re: Antenna for Philco Radio - by TA Forbes - 11-22-2011, 07:43 PM
Re: Antenna for Philco Radio - by SKW40 - 11-23-2011, 12:08 AM
Re: Antenna for Philco Radio - by 7estatdef - 11-23-2011, 12:48 AM
Re: Antenna for Philco Radio - by TA Forbes - 11-23-2011, 04:53 PM
Re: Antenna for Philco Radio - by 7estatdef - 11-23-2011, 05:06 PM
Re: Antenna for Philco Radio - by Texasrocker - 11-24-2011, 12:11 AM
Re: Antenna for Philco Radio - by TA Forbes - 11-24-2011, 03:59 PM
Re: Antenna for Philco Radio - by Texasrocker - 11-27-2011, 01:04 AM
Re: Antenna for Philco Radio - by Marsupial - 11-27-2011, 01:44 AM
Re: Antenna for Philco Radio - by TA Forbes - 11-27-2011, 02:29 AM
Re: Antenna for Philco Radio - by Marsupial - 11-27-2011, 10:45 AM
Re: Antenna for Philco Radio - by TA Forbes - 11-27-2011, 10:03 PM
Re: Antenna for Philco Radio - by BDM - 12-08-2011, 11:26 AM
Re: Antenna for Philco Radio - by BDM - 12-08-2011, 11:30 AM
Re: Antenna for Philco Radio - by codefox1 - 12-08-2011, 12:18 PM
Re: Antenna for Philco Radio - by BDM - 12-08-2011, 04:39 PM
Re: Antenna for Philco Radio - by fixinmyphilco - 12-10-2011, 08:24 AM
Philco 91 Tuning Condenser
