pilot lamp
A #55.
From my Parts Values section of my site:
http://www.philcorepairbench.com/lamps.htm
Chuck
pilot lamp - by fixinmyphilco - 11-28-2011, 08:59 PM
Re: pilot lamp - by Chuck Schwark - 11-28-2011, 10:20 PM
Re: pilot lamp - by fixinmyphilco - 11-28-2011, 10:26 PM
Re: pilot lamp - by DeckApe - 12-11-2011, 12:57 PM
Re: pilot lamp - by Gene Pederson - 12-24-2011, 11:37 PM
91H Code 126 Restore
