How do I remove the stylus from philco 46-1203
I've had to remove the changer from the radio and turn it upside down on the bench to get to the cartridge and/or stylus before. But I do not claim to be an expert on phonographs, especially the 1946-1948 Philco changers that all seem to have this problem.
Re: How do I remove the stylus from philco 46-1203 - by Ron Ramirez - 11-29-2011, 05:15 PM
Philco 91 Tuning Condenser
There are currently 4329 online users. [Complete List]
» 2 Member(s) | 4327 Guest(s)
