Philco 47-1230 Knobs & phono question
Hi Bill
I'm currently away from home, so I can't scan the knobs you seek at present. Perhaps someone else will step in and do so...the knobs are unique to 1946-1950-ish models.
There is, or was within the past day or two, a complete changer on eBay that would work well as a replacement for you. As I recall, it had the dynamic reproducer also. The dynamic reproducer can work very well if it has not been tinkered with; their main issue is that owners have tended to force standard steel needles into the reproducer cone, where only a special sapphire stylus is designed to fit, ruining the cone and resulting in distorted sound. If this has happened to one you end up with, try West-Tech or Syl Vanier to get it rebuilt; just be sure and send in the entire head, cover and all; do not attampt to remove the cartridge from the head. Don't ask me how I know...
Incidentally, you may be interested in knowing that Philco's "dynamic reproducer" is a magnetic cartridge.
Philco 47-1230 Knobs & phono question - by bill T - 10-12-2006, 06:38 AM
[No subject] - by Ron Ramirez - 10-12-2006, 09:19 AM
[No subject] - by Ron Ramirez - 10-12-2006, 09:31 AM
Good Info !!! - by bill T - 10-12-2006, 08:21 PM
[No subject] - by Ron Ramirez - 10-16-2006, 03:55 PM
[No subject] - by bill T - 10-18-2006, 07:40 PM
[No subject] - by Ron Ramirez - 10-18-2006, 11:21 PM
[No subject] - by Poston Drake - 10-19-2006, 01:03 AM
[No subject] - by bill T - 10-20-2006, 06:57 AM
[No subject] - by bill T - 10-20-2006, 07:26 PM
[No subject] - by 49Stude63 - 10-20-2006, 10:53 PM
[No subject] - by Ron Ramirez - 10-21-2006, 08:30 PM
[No subject] - by bill T - 10-25-2006, 10:54 PM
Final answer on knobs - by bill T - 12-17-2006, 08:40 AM
There are currently 9659 online users. [Complete List]
» 1 Member(s) | 9658 Guest(s)
