Bad Transformer?
#35
Your 40-180 is a 7 tube/3 band set. When you do get it right, which I am sure you will, it will sound better and get better reception than your car radio.
From where you live you should easily pull in stations from Atlanta at night, assuming that you outfit your set with a good antenna.
Additionally, with your two shortwave bands you should be able to pickup many overseas broadcasts, especially at night.
Bad Transformer? - by Dark High - 10-28-2011, 09:19 AM
Re: Bad Transformer? - by Texasrocker - 10-28-2011, 03:15 PM
Re: Bad Transformer? - by Dark High - 10-28-2011, 08:00 PM
Re: Bad Transformer? - by Arran - 10-28-2011, 09:19 PM
Re: Bad Transformer? - by gvel - 10-29-2011, 10:28 AM
Re: Bad Transformer? - by Dark High - 11-14-2011, 09:32 PM
Re: Bad Transformer? - by 7estatdef - 11-15-2011, 12:30 AM
Re: Bad Transformer? - by morzh - 11-15-2011, 12:10 PM
Re: Bad Transformer? - by Chuck Schwark - 11-15-2011, 12:36 PM
Re: Bad Transformer? - by codefox1 - 11-15-2011, 02:28 PM
Re: Bad Transformer? - by Dark High - 11-15-2011, 03:45 PM
Re: Bad Transformer? - by Ron Ramirez - 11-15-2011, 05:13 PM
Re: Bad Transformer? - by Dark High - 11-16-2011, 05:56 PM
Re: Bad Transformer? - by 7estatdef - 11-16-2011, 07:05 PM
Re: Bad Transformer? - by james1095 - 11-17-2011, 02:43 AM
Re: Bad Transformer? - by Dark High - 11-17-2011, 09:17 PM
Re: Bad Transformer? - by 7estatdef - 11-17-2011, 11:44 PM
Re: Bad Transformer? - by Dark High - 11-18-2011, 10:33 AM
Re: Bad Transformer? - by Dark High - 11-18-2011, 04:04 PM
Re: Bad Transformer? - by morzh - 11-18-2011, 10:24 PM
Re: Bad Transformer? - by Dark High - 11-21-2011, 01:14 PM
Re: Bad Transformer? - by 7estatdef - 11-21-2011, 02:03 PM
Re: Bad Transformer? - by james1095 - 11-22-2011, 01:33 AM
Re: Bad Transformer? - by Dark High - 11-22-2011, 10:53 AM
Re: Bad Transformer? - by codefox1 - 11-22-2011, 04:47 PM
Re: Bad Transformer? - by 7estatdef - 11-23-2011, 12:28 AM
Re: Bad Transformer? - by Texasrocker - 11-23-2011, 10:41 PM
Re: Bad Transformer? - by james1095 - 11-25-2011, 03:20 AM
Re: Bad Transformer? - by Dark High - 11-28-2011, 01:00 PM
Re: Bad Transformer? - by Dark High - 11-28-2011, 01:01 PM
Re: Bad Transformer? - by Dark High - 11-28-2011, 04:19 PM
Re: Bad Transformer? - by morzh - 11-28-2011, 06:25 PM
Re: Bad Transformer? - by Dark High - 11-29-2011, 11:54 AM
Re: Bad Transformer? - by morzh - 11-29-2011, 05:52 PM
Re: Bad Transformer? - by TA Forbes - 11-29-2011, 08:27 PM
Re: Bad Transformer? - by 7estatdef - 11-29-2011, 09:28 PM
91H Code 126 Restore
