Alignment instructions needed
I need alignment instructions for my Philco 71. Have been told they are the same for the 70 as well.
I posted this in my 71 thread but to replies so figured id try this.. 8)
-Keith
Alignment instructions needed - by ipwizard - 01-01-2012, 05:18 PM
Re: Alignment instructions needed - by 7estatdef - 01-02-2012, 01:04 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 12:45 AM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 01:14 AM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 07:31 AM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 01:46 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 05:55 PM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 07:16 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 08:50 PM
Re: Alignment instructions needed - by 7estatdef - 01-04-2012, 11:12 PM
Re: Alignment instructions needed - by ipwizard - 01-04-2012, 11:46 PM
Re: Alignment instructions needed - by 7estatdef - 01-05-2012, 12:16 AM
Re: Alignment instructions needed - by ipwizard - 01-05-2012, 01:42 AM
Re: Alignment instructions needed - by ipwizard - 01-05-2012, 02:00 PM
Re: Alignment instructions needed - by 7estatdef - 01-05-2012, 07:14 PM
Re: Alignment instructions needed - by ipwizard - 01-06-2012, 12:57 AM
Re: Alignment instructions needed - by John R - 01-06-2012, 01:29 PM
Re: Alignment instructions needed - by ipwizard - 01-09-2012, 12:31 AM
Re: Alignment instructions needed - by 7estatdef - 01-09-2012, 09:23 AM
Re: Alignment instructions needed - by ipwizard - 01-09-2012, 01:56 PM
Re: Alignment instructions needed - by ipwizard - 01-11-2012, 12:33 AM
Re: Alignment instructions needed - by ipwizard - 01-13-2012, 01:41 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7772 online users. [Complete List]
» 2 Member(s) | 7770 Guest(s)
