Philco 47-1230 Knobs & phono question
This eBay ad shows the correct knobs you need, even though it is a totally different postwar model.
http://cgi.ebay.com/290038632560
Here's the record changer, comes with a speaker too:
http://cgi.ebay.com/130034689031
It is from a 48-1270 according to the ad, but should fit your set. It ends tomorrow evening and currently has no bids, so go for it and good luck!
Philco 47-1230 Knobs & phono question - by bill T - 10-12-2006, 06:38 AM
[No subject] - by Ron Ramirez - 10-12-2006, 09:19 AM
[No subject] - by Ron Ramirez - 10-12-2006, 09:31 AM
Good Info !!! - by bill T - 10-12-2006, 08:21 PM
[No subject] - by Ron Ramirez - 10-16-2006, 03:55 PM
[No subject] - by bill T - 10-18-2006, 07:40 PM
[No subject] - by Ron Ramirez - 10-18-2006, 11:21 PM
[No subject] - by Poston Drake - 10-19-2006, 01:03 AM
[No subject] - by bill T - 10-20-2006, 06:57 AM
[No subject] - by bill T - 10-20-2006, 07:26 PM
[No subject] - by 49Stude63 - 10-20-2006, 10:53 PM
[No subject] - by Ron Ramirez - 10-21-2006, 08:30 PM
[No subject] - by bill T - 10-25-2006, 10:54 PM
Final answer on knobs - by bill T - 12-17-2006, 08:40 AM
There are currently 5148 online users. [Complete List]
» 1 Member(s) | 5147 Guest(s)
