41-616 needs feet?
Hello all
While the more important work of restoring functionality goes on (thank you Alfred Corbin!), I also need to pay attention to the cabinet of this amazing set, which is missing feet...(?)
Pictures I've seen show feet on this cabinet and I've seen similar sets (different years?) without...
I'm posting this preemptively as the materials I'm getting from Chuck Schwark will probably answer the question but assuming the set came with feet, I'll need a set regardless.
Is there a template or detailed drawing of these to scale available in the restoration world to recreate these feet if an authentic set can't be found? I'm assuming they're all the same...
Any help is deeply appreciated...
Mark
41-616 needs feet? - by mat68046 - 12-01-2011, 01:26 AM
Re: 41-616 needs feet? - by rocketeer - 12-02-2011, 10:04 AM
Re: 41-616 needs feet? - by Ron Ramirez - 12-02-2011, 09:02 PM
Re: 41-616 needs feet? - by mat68046 - 12-04-2011, 06:08 PM
