help with philco ID
This is what I can tell you about it. It is an AC model (has a power transformer) Is in a 1929 Lowboy cabinet with an odd speaker grille. If I had to guess I'd say your right (65) but I'm not real familiar with the early large chassis set except for the 87 and 95. You can probably figure it out by the tube count and the type of tubes. The older sets will use 26's and the newer ones will use the 24A's
help with philco ID - by fixinmyphilco - 01-05-2012, 06:32 PM
Re: help with philco ID - by 7estatdef - 01-05-2012, 11:09 PM
Re: help with philco ID - by fixinmyphilco - 01-06-2012, 09:22 PM
Re: help with philco ID - by Ron Ramirez - 01-06-2012, 11:00 PM
Philco 91 Tuning Condenser
There are currently 4591 online users. [Complete List]
» 2 Member(s) | 4589 Guest(s)
