37-610T
I have been trying to find ONE piece of walnut veneer to do the front of my 37-610T ,sizes seam to be too small, now I have a Atwater Kent 55 [one of several] this is a parts set. It has a piece of walnut veneer the size that would work on my 37-610T, on it's top ,it has started lifting, but in good shape ,can I use it on the 37-610T ? has anyone out there done this? Seams Like I've heard of this being done
37-610T - by BILL - 12-01-2011, 12:31 PM
Re: 37-610T - by TA Forbes - 12-02-2011, 12:07 AM
