Another Philco rookie joins the Phorum
Hi BOBC,
Welcome to the Phorum. I am in Charleston, W.Va., not far from you. Glad to hear of a Philco fan in Cincinnatti, most radio hobbyists I know of in your area of fans of Crosley. And understandably so, as Powell Crosley built some great radios in Cincinnati and was a real pioneer in radio and television broadcasting. But better than that, he built the Cincinnati Reds which most of us over in Charleston follow almost as a home-town baseball team.
Sounds like you have acquired some nice radios, especially that 37-620 chairside. Sorry I can't help on the trim ring but maybe others here on the Phorum will have ideas for a source.
Poston
Another Philco rookie joins the Phorum - by BOBC - 10-19-2006, 01:15 AM
[No subject] - by Poston Drake - 10-19-2006, 01:30 AM
[No subject] - by Chuck Schwark - 10-19-2006, 08:51 AM
[No subject] - by Ron Ramirez - 10-19-2006, 09:19 AM
[No subject] - by BOBC - 10-19-2006, 11:37 AM
[No subject] - by Poston Drake - 10-19-2006, 06:18 PM
Philco 91 Tuning Condenser
There are currently 6549 online users. [Complete List]
» 2 Member(s) | 6547 Guest(s)
