41-616 needs feet?
Thanks, Rocketeer and Ron, for your replies. Seeing the back of an intact 41-616 is a big help. My set has a Garrard RC-80 phonograph which was hacked in while the Mystery Remote control wiring was hacked out of the chassis for some reason, according to Alfred Corbin, who's bringing this one back to life. I'll post in the Electronics thread about that as we need more info.
As Rocketeer noted, the set looks fine without the feet, since I've never seen it with them.
I cannot tell from the photos whether the back two feet are different or just the side view of the front counterparts. Ron, If you can get close ups with some measurements that would be awesome but not time critical. These can always be added later plus I'd need to find someone talented enough to try to reproduce these from a set of photos with basic measurements.
Thank you both...
Mark
41-616 needs feet? - by mat68046 - 12-01-2011, 01:26 AM
Re: 41-616 needs feet? - by rocketeer - 12-02-2011, 10:04 AM
Re: 41-616 needs feet? - by Ron Ramirez - 12-02-2011, 09:02 PM
Re: 41-616 needs feet? - by mat68046 - 12-04-2011, 06:08 PM
